Rubber floor mat
Mike L
Texas
Self employed field mechanic
Is there any companies out there who make an aftermarket floor mat for my kenworth? $900 for a rubber mat in a day cab seems a little bit expensive.
crane operator
sw missouri
At $450 and a "maybe" fit right? Vs. $900 and it will for sure fit?
I don't know - are the KW all the same basic cabs with just different hoods and frame?
1693TA
Farmington IL
FAA Radar Engineer, (Retired)
That is usually what I do along with a section of 32oz sq. yd. weight "Jute" backing and vinyl top contact adhesive to glue them together. Thin "fan fold" styrofoam insulation makes for an easy pattern to cut from, as does silver foil bubble wrap insulation.
RenoHuskerDu
Texas
A friend works at a rock quarry. The generate a LOT of used heavy conveyor belt. If one part tears, apparently the whole chunk goes on the scrap pile.
He brought us a good chunk, we pressure washed it, used a cardboard template in the cab to cut it, and now it's a nice heavy floor mat in my 1984 International S2500 dump truck. Really quieted down the tranny and road noise.
FYI
