Hey,
First off, Roanoke Hustler went out of business WAY before the interwebz, so there's zero info out there on these machines. Google will show you a few for sale, that's it. Wondering if any of the gray hairs on this site have any experience with these machines.
That said, I have an option to buy an old Roanoke Hustler 12k forklift. I would be using it around my shop yard to move equipment here and there, so it doesn't have to be pretty but I do have to be able to keep it working. I would estimate no more than one hour's running time per week if that. Have never bought a big forklift before and would like your advice.
This machine is owned by a customer of mine and they have put it out to pasture. I don't have enough work for a 12k forklift to spend $20,000 on a newer one. Customer wants $3500 for this one, can probably get it for less. I'm seeing comparable-capacity worn-out used forklifts with prices listed at over $10,000 although I have no idea how much they actually sell for.
Dual wheels with 22.5" truck rims out front, driven through a Rockwell truck rear. Engine is a JD 4219D and transmission is a Funk 4000. Single-stage lift raises to 11'. Has raise/lower, tilt, and sideshift. Fork tines are 6' long, have been welded at the heels and need to be replaced. Have one quote at $1500 for a new set of tines, delivered. Steering is shot - bellcrank needs to be bored and rebushed. Rear wheels are old 8" x 20" split rims and tires are holding air but are no good. Brakes and transmission work. No leaks at any of the mast cylinders, and I left the mast a foot off the ground for a week with no drift at the main cylinder rod and only slight drift (3/8") at the tilt cylinder rods.
Roanoke Hustler parts dried up a long time ago, but I'm wondering if that really matters as long as I can rebuild what's in the machine. I'm a one-man business, so I don't have a ton of money to blow on something that gets limited use. I would think something like this could be made to work for a long time to come at less than 50 hrs per year, but your thoughts would be appreciated as I don't buy much heavy equipment.
Thanks in advance.
Thanks in advance.
