reviews use performance "pull dozer" scraper
trombeur
italia
img.axd
hi, what do you think of pull dozers, bulldozer blades pulled by tractors, what use do they have, what limits what performance?
what flaws. in our parts peasants use them to level the rice fields, from you? it is an agricultural rather than industrial tool. let me know
ovrszd
Missouri
Retired Army
Similar implements are used here for Agricultural purposes. As you mentioned, leveling fields, creating drainage areas, etc.
Most here are lighter duty than this one and are stretched out longer with the rear wheels farther from the tractor. This increases their ability to cut a level, flat grade.
That thing is a Beast!!!! :)
Yes, very similar to what is done here in rice producing areas or other fields that are flood irrigated. In the old days, long wheelbases were used to level, now with automatic grade controls like GPS, laser, etc. the wheelbase isn't needed, the hydraulics allow a three point blade to produce a perfectly flat surface with no roller coasters.
Heavy blades like that are more economical for ag and some construction purposes than bulldozers. Just like pull pans are more economical than motorized scrapers in similar situations. Bulldozers are still needed for clearing wooded areas, anything with stones or concrete.
trombeur
italia
I think the crawler bulldozer would be better, it pushes instead of towing in my opinion it has more thrust and then the tracks and the low center of gravity make the structure more balanced they distribute the strength and the thrust better, maybe a towed implement if it encounters an obstacle a boulder a big one tree root stitches and creates damage or the uneven surface, the towing scraper I believe is used after you have roughed it with the traditional crawler bulldozzer or better the grader, to correct imperfections and restore the floor if it has yielded somewhere and has settled on ground maybe after a heavy rain, am I wrong?
No undercarriage wear to worry about with a pull dozer over large fields. I think you could go faster and they'd be more efficient for long dozing runs. I don't think they would do heavy digging as well as a standard dozer.
Get a rear view camera. With an automatic laser system you only have to look back occasionally.
ovrszd
Missouri
Retired Army
Bit off topic. My large Row Crop Farmer friend plants corn with the Captain's chair turned 45 degrees, legs crossed, arms folded. GPS technology is amazing!!!
farmerlund
North Dakota
Farmer/ excavator
new-005-jpg.156748
I have this set up. I works very will for leveling and shallow ditching. Ends flip up so it can be a 6 way blade. When leveling large building pads, I can keep up to 4-5 belly dumps on a short haul. Will not cut into really hard ground like a dozer, but really good for loose fill and gravel.
