Replacing MF 50HX front hub seal
mik
australia
I am attempting to replace the front hub seal on a 4wd MF 50HX , my question is , am i able to replace the seal by removing the outside cover and gaining access from there or do I have to remove the complete assembly from the machine and disassemble the hub from the rear?
I have attempted to remove the outside plate that fits over the wheel studs and is retained by two hex screws but it is extremely tight.
stock
Eire
We have moved on and now were lost....
What year is the machine??
stock
Eire
Is that a center line front drive shaft? nearly sure it is .............................give me a while...................
Knoxville TN
Service Manager
Welcome to the forum mik. :usa
I started a new thread about your question because it deserved it's own thread and thread title, makes it easier for members in the future to source the info in the thread. :)
Nice find on the drawings Stock, looks like the same axle Case loader/hoes uses. ;)
BTW mik, on those socket head cap screws, sometimes it helps to bang on the head of them with a brass drift, and a really handy tool for socket head cap screws is a hand impact tool.
http://compare.ebay.com/like/230608...f66a7d0&itemid=230608403275&ff4=263602_324952
AussieChris
Brisbane, Oz
I think the 50HX came with either Carraro or ZF front axles. You might need to identify which one you have.
Chris
Brisbane Australia.
stock
Eire
off set shaft was ZF
mickos
Hi,
Please see attached photo.
I have a MFHX and trying to find what this part is called in the photo to replace the seal or something Its the front 4x4 drive that attaches to the front diff. Its pouring out oil all over the place. There is about 2mm of movement so I assume there must be a bearing in there. But thought there must be a seal there that I can replace to stop the fluid coming out. I bought a workshop manual but I cant find this part.
Any help would be muchly appreciated.
Thanks.
