Old Magnet
Yes, sounds like the left brake adjuster is froze up or the threads are corroded. There is a large drain plug under the steering clutch compartments for draining. Can be drilled for a cotter pin wiggler for permanent drainage.
There are techniques for washing the clutch compartment described in the Owners Instruction Manual but that is only a temporary fix. Usually it's the pinion seals that cause the problem as they are high in the housing and dribble on to the hub and drum. Bevel gear compartment seals can also leak but the oil normally does not get to the brakes unless the compartment fills to where the drum dips in the oil. Yup, looks like your in for some serious repairs.
