Replacing 650J cab mount isolators
bchand220
USA
Looking for any advice on the process to replace the isolators on a JD 650J cab dozer. Is it simple? Any special tools required? Does the cab have to be removed?
Thanks
mg2361
Pennsylvania
Equipment Mechanic
No special tools. If you have lifting capabilities you should be able to get away with lifting it just enough to replace the isolators.
bchand220
USA
Ok. I can use a trackhoe but would prefer to use a bottle jack or wedge. Do you know about how high it needs to be lifted to get swap them?
mg2361
Pennsylvania
Equipment Mechanic
A trackhoe would not be safe so I would not use that. You should only have to lift the cab the distance of the protrusion on the one half of the new mount, maybe 2+/- inches.
