Repairing older style dozer final drives D6D
OzDozer
Perth, Western Australia.
Semi-Retired ..
Woo-Hoo! One of my old steeds! An ex-Army S-7 Euclid elevator scraper!! I didn't know there were any still running! These are 1960's machines!
.RC.
Qld, Australia
They were telling me they had a pair of them, except the other one is a twin power. Another GM to drive the elevator. :D
Queenslander
And, if Iam not mistaken, a 14C hiding in the background.
We’ve had about 10 inches in the last six weeks but hardly run a drop of water.
Certainly not enough to fill a dam.
OzDozer
Semi-Retired ..
Yes, the S-7 had a 4-71 for main power (135HP from memory), 4 speed Allison, and a 2-71 to drive the elevator. Spent enough time on them, to lose a fair amount of my hearing!
.RC.
Qld, Australia
I will resurrect this thread as the issue stems from it. I have not done anything about it as it has run sort of fine. There is no binding or anything.
After I put everything back together and installed the track frame, it was never aligned properly with the bottom rollers. Before I pulled it apart it was. The is probably 3/8"- 1/2" out of alignment (in towards the tractor too far)and now some time has passed and the chain will rub on the sprocket. Not bad, but it rubs. The diagonal brace bearing is also all jammed over one side and there is room there to move it outwards to correct the alignment.
Now I know there are shims that you put under the dead axle nut for alignment, however this is only for minor movement of the track frame. Not for 1/2" of moving it.
I have been racking my brain as to why it never went back in the same position I pulled it apart. I thought as I replaced the hub, maybe the aftermarket one was made all wrong and the sprocket was incorrectly positioned, but it projects the same distance from the tractor frame as the other side. So no issue there.
The only other thing it could be is the outer support, the bit that sits on the taper and you tighten with the nut on the dead axle. I replaced it with an aftermarket one, and it is it that aligns the track frame with the rollers.
So for the older people that remember these old designs, have they ever had an issue with track frame alignment from out of spec parts?
I did find this thread with a similar problem, but as usual, no known outcome.
Glum
South Africa
Having 3 lots of tapers, (axle to casing, sprocket to hub, axle to holder) that have been pushed, pulled and replaced who knows how many times in 40 years has this effect I guess. I would remove the nut and put as many shims as you have behind the retainer plate to force the track frame out and see how much it improves.
OzDozer
Semi-Retired ..
RC, you're already onto it - it's the variation in taper on the aftermarket outer hub you purchased.
It doesn't take much variation in taper to position the hub either in or out quite a distance from the original position of an original hub.
There's not much you can do about it, if the outer hub is positioned too far in. The only cure is machining it out and sleeving it with a tapered insert, to get it positioned out further.
.RC.
Qld, Australia
Thanks, there is some amount of thread showing on the nut when I pulled the outer plate off.
Maybe Glums idea of making up a thick shim will work. It is the easiest and cheapest.
Anpther thing just dawned on me is I thought the outer cover plate was just that, merely a plate to cover and seal everything up. But I think it is also supposed to pull the track frame out and press against the inner circular bit that has the red grease on it in the picture below.
Glum
South Africa
Yes, RC, that's exactly how it works. Shims behind the plate, to move it outward on the axle, then when you tighten the outer cover up against the retainer plate it pulls the whole frame outward.
.RC.
Qld, Australia
Of course if the outer hub is pushed on more, it also means the duo cone seal is squashed up more. Tolerances stacked upon tolerances upon tolerances.
You can see now why International were way ahead of Caterpillar on final drive design back in the 1960's and 1970's with their separated from the trackframe planetary design.
