Complete axle diagram
1 18C1224 1 BOLT 1.50''(38,1 mm) long
1 6679247 1 BOLT plated - 1.75'' (44,5 mm) long
2 6552871 1 WASHER
3 7134137 1 SPROCKET Was 6577204
4 6689775 2 BEARING, AXLE Was 6519925
5 6689638 2 CUP, BEARING Was 6634609
6 6658228 1 SEAL, OIL
7 1 AXLE NAP - W/ .75'' dia. x 1.25'' deep full threaded end - Use W/Ref. 1 ( 18C-1224 bolt) - Was 6706427
7 6706427 1 AXLE W/ .75'' dia. x 1.50'' deep full threaded end - Use W/Ref. 1 (6679247 bolt)
8 6709170 8 BOLT, WHEEL Was 6559502
9 18C1636 1 BOLT 2.25''(57,2 mm) long
10 6716843 1 WASHER recessed
11 6578689 1 HUB W/Ref. 8
12 6J1664 1 KEY
13 6563606 1 WASHER recessed - Used to take up .005 or .010 end play on axle
14 6564669 8 NUT, 10 wheel
15 6662306 1 RING wear - service part only
15 6722907 4 KIT See Illustration AXLE SEAL KIT/ B4041 - axle seal & wear sleeve
16 1 O-RING NSS - if equipped - for production use only
