Mike L
Looking at smaller welders for the home shop. I have 110 and 220v In my shop. I’m looking for a smaller mig welder that also has the ability to add a spool gun for aluminum without breaking the bank for home projects.
If you plan to mig aluminum of any thickness get at least a 250A machine with a 60% duty cycle rating at a minimum. You will be marginal with 3/8" there but it will work if going slow. Aluminum takes a lot of heat and this easily taxes the smaller units. As suggested the smaller inverter types are a lot less weight but I've not much experience with them for durability myself.Looking at smaller welders for the home shop. I have 110 and 220v In my shop. I’m looking for a smaller mig welder that also has the ability to add a spool gun for aluminum without breaking the bank for home projects.
There are feeders available that do not rely upon the welder other than output power. My Hobart feeder is this way in that you attach it's input leads to the output of the welder and everything is controlled at the feeder pertaining to start, stop, and wire feed. It has an internal contactor so the tip and wire are not live till you squeeze the mig gun trigger.I run a miller bobcat 260 on my truck and that doesn’t have the ability to run a suitcase welder. I looked into that. I’m leaning towards a miller or Lincoln just because I have a dealer in town And no matter where you go there seems to be a dealer.
Linde were good machines and often had inductance control so you could fine tune the arc just how you wanted it.About two years ago I bought a new Hobart Ironman 240-$1,550. It's set up for spool gun.
For the money it's a real good welder. I've used allot of different brands through the years,
Linde I liked the best but Linde is no more.
