Ricothebear
Hey everyone, so I decided to get my hands dirty again and have a go at fixing a leaking hydraulic pump in a JCB telehandler. It was leaking about a drip every minute, so It was pretty bad. The foreman who was using it said it had been leaking like that for a month. but it only leaked when you shut it off (makes sense because the vacuum created by the pump kept the oil from leaking during use. Then he would park it over a drip pan and turn it off).
I've never done this before but I have worked on automotive transmissions in the past, so I figured this would be the same principle. Pull pump, disassemble, inspect, replace seals (best case) Replace pump (worst case)
I drained the units hydraulic tank and pulled the pump off already. I'm going to disassemble it tomorrow but I wanted to be sure I'm not getting ahead of myself here. So I thought I'd ask here first:
1. Is there any visual indicators that the current pump is garbage
2. Would you bother replacing seals (is it worth the risk of having it leak again) or just get a new pump (cost of JCB seal kit is 70$ , cost of new pump is 950$)
3. What is typically the cause of the pump seal failing?
4. any other advice or suggestions for a first timer here?
