I am seriously considering replacing the rear end in my dump truck. It is currently equipped with Pete Air Leaf (low). I am looking for a used "take-out" that is better suited for off-road but will still yield a decent ride on pavement. My current ruck has had the frame stretched (so it has a sleeve) and the dump bed has a sub-frame on it too. The suspension does not articulate very well, and when coupled with the lack of flex, through the frame, it makes traction suffer when empty or pulling loaded equipment trailers up gravel road grades. Most driving is local rural mountain roads. Nearest freeway is +/- 3hours. Will carry up to 54,000# gross (legally anyway). Often pull tri-axle trailer (loaded trailer weight up to 62,000# but usually +/- 54,000#).
I was thinking Chalmers but, so far, I have only been able to locate a Hendrickson HN (not sure if it's 402 or 462). I've been to Hendrickson's site and they also call it a Haulmaax suspension. I have no experience with this suspension.
Does anyone have any experience with this suspension? I would like to know:
Does this suspension articulate well?
How well is it holding up?
How does it ride over the road?
What should I look for when previewing?
Weak points?
Pros and cons?
Overall impression?
Lastly, I am also considering getting different gearing (maybe a little lower). The truck currently has 3.90s in it (10 spd. trans, 22.5 tires), and it will run to about 80 MPH (I've driven it to CA a couple of times). It seems as though I can get 3.90s, or 4.33s in the new rear take-out. I'm not sure if I want to go as low as 4.33. I was thinking that 4.11s might be better. Thoughts?
Weak points?
Pros and cons?
Overall impression?
