Ready for Another 23,000 hrs.
Randy Krieg
Arizona
Test Pilot/Operator @ Caterpillar's Tucson Proving
We finished our rebuild & repaint this week. I took it for a little snowplowing spin today. Just like new again! I used the flash in some of the pictures to show how the decals light up at night. Very soon it will be loaded on a lowboy and headed to the North Slope of Alaska where it will spend another season enduring some brutal conditions..........:cool:
ovrszd
Missouri
Retired Army
Lookn good Randy!!!
I've never saw lights mounted on the top of the lift cylinders before!!! My Deere has them on the side of the main frame just ahead of the lift cylinders and on the bottom front corners of the cab. Never thought about using the top of the lift cylinder!!! You'll hafta give us a working shot sometime when using the lights.
Alberta
alberta
maintenance supervisor
Sweet !!!!! Love the sandvicks on the ripper.
joispoi
Connecticut
Looks like a brand new machine. What upgrades if any were done to it for working in the cold temperatures?
Randy, With all those additional lights installed are you still using the standard alternator..?
Have you tried LED's as work lights ..? 17 watts of power consumption versus 70 for a conventional halogen lamp. We're experimenting with them on our 16's at the moment and initial feedback is very positive. You have to be careful to select the correct type though, there are both spot & flood configurations available and the beam that each one produces is totally different.
big ben
Vancouver Island
What is with the 2 intakes ? I see the regular pre-cleaner and then what looks like another intake behind. I have not seen this set up before.
JTL
Pacific Nortwest U.S.A.
IUOE Local 302
The only thing that would make that machine look better, is my ass in the seat!
Looks better than a new M any day..
michael james
36 years working for a council, last 12 as a grade
If you look at page one of "GOING TO SEE THE SANDMAN", the pre-cleaner setup is explained.
Randy Krieg
Arizona
Thanks for the Compliments and to Answer Some Questions.
Thanks for the Great Compliments! It was a fun project.
To answer some questions:
The stop/tail & indicators lights on the ripper bar are from a 789 haul truck and use halogen bulbs. I did this mainly to keep the rear visible during a phase II or phase III blow. During a blow the graders are responsible for plowing the road and leading the crews back to camp, we get in a caravan and the trucks all try to stay as close as possible. I turn off the rear work lights, which are on a separate switch, so they don’t get white spots in they’re eyes and run the rear flashers. The halogen bulbs put out just enough heat so they don’t cake up with snow and ice over. The reverse lights on the ripper are tied in to the reverse switch on the transmission and only come on when the machine is in reverse. I set it up this way because I don’t like the ripper all lit up when I’m backing up at night. Having the lights on the back of the ripper instead of ahead of the ripper, this eliminates the glare and shadowing going on behind the machine.
In the summer time they work great as indicators; my one roller hand referred to them as “The Get the Heck out of Way Lights”. She said “When I see those lights come on I’m switching to reverse”!
In regards to the lift cylinder mounted lights; this is the third machine that I have setup with these lights. It works really nice since the light pattern moves with the drawbar sideshift. As you centershift either way the lift cylinder leans and the light pattern moves in that direction.
Nige, this 14H has the optional 100 amp alternator. Yes; we have tried LEDs and though the lighting is great and the amperage draw is far lower they simply don’t put out enough heat to prevent them from icing over or caking up with snow. In a blow up north the lens will literally get covered with snow and block the light. I did switch all the tail/stop & indicator lights to LED; one taillight was over $160.00, OUCH! Plus I then had to cut off the “Sure seal” connector and install “Deutsch” connect to machine wiring harness to keep it all weather proof. The new LED tail and indicator lights come from CAT with Deutsch connector pigtails. Two months ago while we were testing at the Tucson Proving Grounds we tested four different LED lighting packages on a 16M. The lighting was fantastic and on the Quad LED it was so good that it would cause problems for the haul trucks passing the grader. Even the Quad barely put out any heat and there was actually talk about putting a small heater in the lamp holder to prevent it from caking up with snow. Solve one problem only to create another!
Joispoi, in regards to cold weather preparation and winter time operations. The machine has synthetic oil in every compartment (Hyd. Tandems, Trans. Circle Drive) except the engine. It has a Huber Reversible fan, all quilted insulated winter covers, a 20,000 btu auxiliary heater, the engine coolant lines running to both heaters are all covered with insulated blankets, 110 heating pads on the hydraulic tank, trans & engine, 110 engine coolant block heater, chain hanger beam just behind the radiator, the hydraulics are all plumbed for a reversible nose plow and rear wing, another complete set of snow tires and it has the warm air/cold air engine intake system mentioned in the “Sandman” thread.
Just to give some an idea of what it's like for visibility, I shot this picture last year while I was in a pickup headed back to camp after going out to fuel up some light plants. We had to follow behind our 16M as it was blowing Phase II conditions. If he gets just a little too far ahead you instantly lose sight of the machine and the road which he is plowing for you will drift back in very quickly. Not fun when it's around 70 below 0 windchills!
Regards, Randy
>HevyIndsMFGng<
Oshkosh, Wis
Mechanic/Student
Thanks for the reply post Randy, all of the information and pictures were really cool to see and learn about.
Thanks again,
Logan
Randy, Thanks for the response. Fortunately in our climate I don't have to think about snow ....!! I was looking more at the issue of the high current draw from the alternator of the machine lit up like the proverbial Christmas Tree and its' effect on the main wiring harness.
If it was me I would take the hit and swap all the Sure-Seal connectors on the machine to Deutsch, at least on the lighting circuits. Far more reliable at keeping out moisture in my experience.
