I have used ether for years on different engines with no detrimental effects. Our Champion grader has a GM 471 which needs a sniff first thing in the morning and while some say that GM’s must be worn out if they need ether, this one isn’t showing any signs of a worn out motor. It is also equipped with the cold starting ether canister, so the manufacturers must think it is OK to use ether. I have also seen some John Deere tractors out here, fitted with the ether starting aids, so John Deere must also think it is OK to use it.
This brings to mind and incident that happened many years ago. We had an International AWD 7 farm tractor fitted with glow plugs and once the batteries got down a bit, it was really hard to start. There probably is a North American equivalent to this tractor, but I do not know what the numbers are. The shed we kept it in was on a hill, so in the mornings, we would heat it with the glow plugs, roll it out the shed, throw it in to road gear and jump start it. This particular morning it would not start and we had ran out of hill, so the old man sprayed some ether into the air intake and it still would not start. By now the batteries were getting pretty sluggish. I do not know who made the decision, but I tried the glow plugs again. Next thing there was a god almighty bang, the old man jumped about six feet in the air, the tractor was covered in oil, the built up ether in the air intake had exploded and blew the pan clean off the bottom of the oil bath air cleaner, sending oil everywhere. Needless to say, I did not do that again.
Rn’R.
