Question about mills?
Discussion in 'Mills' started by Airedale, Dec 12, 2009.
  1. Airedale
    Airedale Active Member
    Nov 26, 2009
    34
    North Dakota
    Is there any kind of mill or machine that can be used to level hard frozen ground ( as hard a concrete ) with ruts and frozen clumps? The machine would not have to pick up the material just break it up in small pieces and leave it flat on the ground. It would have to be small enough to get into tight spots in confined areas. Possibly on a skid steer.
    Any ideas would be appreciated.
    Airedale
  2. AtlasRob
    AtlasRob Senior Member
    Feb 8, 2008
    1,982
    owner operator
    West Sussex UK
    patch planer
    For small confined areas how about a patch planer. Used for cutting out patches in tarmac for repairs. Basically a small mill.
    I dont support / work for or anything else for JCB it was the first link in Google with a picture.
    http://www.usinenouvelle.com/industry/jcb-2950/patch-planer-p22815.html
    The another option would be a rotating head
  3. krisjanik01
    krisjanik01 Member
    Dec 12, 2009
    10
    australia
    yep thats it a skid steer profiler/cold planer. cat,hydrapower and bobcat and more make them also you need a high flow skid steer with aux hydraulics.
  4. Airedale
    Nov 26, 2009
    34
    North Dakota
    Do they have to be used on flat ground? What I would like to use one on is frozen compacted snow and mud with ruts and holes 6 to 10" peaks and valleys.
    I pretty much want to make it flat. Not in one pass but so you could drive or walk over it without breaking something. Grading will not work the high temperature today will be about -4 degrees Fahrenheit.
    Airedale
  5. AtlasRob
    Feb 8, 2008
    1,982
    owner operator
    West Sussex UK
    Not at all, use it at any angle you like provided the carrier machine can hold it.
  6. krisjanik01
    krisjanik01 Member
    Dec 12, 2009
    10
    australia
    if its a really big area your best to use a 600mm or even 1 meter heavy the better and the biggest skid steer like a case 465 or bobcat s250 will help you get it done alot faster with less stress on the skid steer :bash
  7. milling_drum
    milling_drum Senior Member
    Aug 19, 2008
    724
    asphalt mill operator (ret)
    out west lately
    Without searching out the links, most companies that make bobcat/skidsteer/mini loaders usually carry a pretty good selection of small mill heads....Krisjanmik makes a good observation about making sure the power source is has a high flow hyd setup on it.....
    That head Atlas Rob pictured looked impressive as well, never seen one though.
  8. Airedale
    Nov 26, 2009
    34
    North Dakota
    Thanks, everyone for the information from all around the world!
    Amazing,
    Airedale
  9. krisjanik01
    krisjanik01 Member
    Dec 12, 2009
    10
    australia
    check this out called a road header used to dig offramps and so on along with a tmb pretty cool. that pic Atlas Rob is excavator mounted.
  10. SAH
    SAH Member
    Nov 29, 2009
    11
    equipment operator, mills,dozers, scrapers, articu
    north central PA
    thats cool, never seen anything like it
  11. AtlasRob
    Feb 8, 2008
    1,982
    owner operator
    West Sussex UK
    The first time I encountered anything like it was on a Cat 973? ( might have been a 963) there is a pic on here somewhere I will see if I can find the original. It was made by Webster http://www.webstertech.co.uk/
    they seem to have come on a bit in the last 15yrs and seem to be available for about any size machine.
    It was a 963 :)
  12. he2009
    he2009 Member
    Dec 21, 2009
    8
    Temecula, CA - U.S.A.
    Milling Heads
    VERMEER - ASPHALT ZIPPER and few others have compact milling heads perfect for this. - Keep in mind the carbide bits vary depending on how tough the material you'll be working on. Since you say you'll be in sub-zero conditions I'd be checking some of the carbide bit grades used on hardened concrete such as airport runways. - Hope this helps
