funwithfuel
Leaks on suction side are a challenge. Since they pull air rather than leak fuel. Try priming her up from an alternate source like a 5 gallon jug of fuel. That way you can see if your fuel level diminishes while priming
That's pretty weak, looks like check valve might be hung open. Are you getting full stroke on the pump lever, or do you have a long dead spot followed by a little resistance?
About 1/2 to 3/4 of the way I feel a little resistance like it's starting to pump.
Maybe just gravity it into the lift pump inlet.
Are you philosophically opposed to finding the problem for some reason? This seems simple, find the problem, fix the problem, done. I don't see what you get by using a temporary tank in this situation. If it starts and runs until the temporary tank runs out, then you know you have a blocked fuel supply, which you already know. Why not find the blockage and fix it? You can use the priming pump to find the blockage, or pressurize the tank and see where you get good flow and where you don't. A piece of inner tube with the valve stem attached, held over the fuel filler opening is an easy way to get a pound or two of air pressure in a tank. Or if there's an overflow/vent tube, hook a clean tube to it and blow by mouth.
