lake side bob
Getting into MIG welding.
My question is which wire size to use with the Horbat Ironman 230 welder.
On this project the MIG was purchased for; is to weld together 1/4 inch steel 3 inch square steel tubing for a rock grizzle frame, I have a 1.75 cy yd wheel loader.
I have been told by an "expert MIG welder" that I should use .030 non flux wire with 75/25 gas mixture.
Because - its like a 5/8 inch water hose with a nozzle compared to a 5/8 water hose with out a nozzle.
Was told the .030 will give deeper penetration into the steel then the .035 wire.
What do you experienced welders say?
Would straight CO2 gas work just as well as 75/25 mix gas? What would be the difference between the two? Never ran into this question with the Miller stick welder.
Should I grind the edges of the 1/4 thick 3 inch steel square tubing before I weld the tubes together to make the frame?
Say grind 1/16 off the edges that contacts the other tube face, the other edges does not contact as they are on the curve of the other tube.
With this Horbart Iron man 230 should I preheat the steel before welding? Read some where on the net about preheating steel before welding with MIG to get deep weld.
Anyone use the Horbart Iron Man 230 Mig welder before, if so what is your impression, I have read positive comments on the web and no negative comments?
