PTO hydraulics on a GMC Top Kick
Shimmy1
North Dakota
Two things. WTF are they using a torch to cut off a 3/8" bolt that would take all of 15 seconds to remove??? Second, who in the hell packages up something that they obviously damaged removing??? I mean, really??
Willie B
Mount Tabor VT
Electrician
Update: With considerable help I've identified the PTO as a Muncie, and discovered the model #. Some strong solvent has drizzled across the printed nameplate obliterating several characters. DuaneB at Welding web has two decades old info about these transmissions, PTOs, and Hydraulics. PTO will run at near engine speed, is rated at many times the HP I will need. Pump will move 31 GPM at 3600 RPM, 3600RPM, and 3000PSI. It should be a good match. I'll call the seller to address the damage to aluminum case. The flange surface is OK. The surface a mounting bolt should contact is a crater, nothing for the bolt to contact. I'll call.
IMG_0468.jpg IMG_0468.jpg IMG_0469.jpg IMG_0468.jpg [
Willie B
Mount Tabor VT
Electrician
The PTO came from California. It is damaged with cutting torch, or plasma. I don't know what to do. The seller will "get back to me"
Willie
Jonas302
mn
Maybe a nice heavy washer like cat uses might find enough surface to tighten down on or have the local welder try to add some back in
Hopefully seller will refund some of the cost
repowerguy
United States southern Ohio
mixer truck mechanic
TIG the hole up and then re drill the hole. It’s the long way home, but it should work.
Might be a good reason as any to buy a TIG setup, I don’t use mine very often but it is handy to have and I stick weld with it also.
Willie B
Mount Tabor VT
Electrician
I'm the local aluminum welder. I feel I can replace the missing metal, but how much the distortion will affect the shape of the gearbox, I don't know.
Theweldor
Western, NY
The Village Idiot
Your just building up the bolt hole. I don't think you will need to worry about distortion.
crane operator
sw missouri
Weld it up and take a flat file and straighten out the side where it mounts on the transmission. I think you'll be fine. It's certainly not worth sending all the way back to california. You might get by even with a self locking nut with the flat side/ washer made into the nut.
crane operator
sw missouri
It kind of stinks that they would send something out like that, all the way from california, I would probably be a little ticked, but it probably isn't worth the hassle of trying to send it back.
If he's willing to send you another one for nothing, I wouldn't turn it down, but if it's full price for a different one, I'd run what you have.
Willie B
Mount Tabor VT
Electrician
I wanted to cry! It was like buying a pig in a poke. I had only the seller stating it was in "good" condition. The truck, and transmission are old enough I can't find this stuff in every salvage yard. It seems these mated PTO/pump combos must match. New was getting very complicated, and 8 times the cost.
oceanobob
oceano california
general contractor
The hole repair has maybe been resolved? The nature of welding aluminum is one thing, aluminum castings the next headache sometimes. Was a braze rod able to fill that depression to allow the fastener an opportunity to hold it onto the trans....
Curious.
Maybe report on progress when time allows, thanks.
Willie B
Mount Tabor VT
Electrician
Curious.
I'm an aluminum welder, but I had the concern that nothing welded is ever exactly the same shape. The seller is LKQ, a big chain of truck salvage yards. The first came from CA, they then sent one from FL. which had been taken apart, bearing, and shift fork replaced in the wrong places, causing some real carnage in the gears, and shafts. Also, the pump had been replaced with one with shorter shaft, and it only partially engaged the half moon key, buggering both keyways.
LKO ultimately has said they don't want to deal with me.
Our local truck parts company was bought out by Fleetpride. It turns out the cost for new wasn't as bad as I had thought.
Willie B
Mount Tabor VT
Electrician
Any news on this PTO for the dump? Figuring if maybe so then it would be here. But then again....
As spring slipped away, I got way busy. Now summer is over, I hope for a bit of a lull in my level of work, and can again spare a few days to work on this. I did buy a new PTO/Pump combination, as repeated attempts at finding used in serviceable condition failed.
The project includes moving everything at the rear of the frame forward about a foot. Removing rivets has been a nightmare! These are, I presume crushed , and headed hot. They are shaped like a whiskey barrel. Removing the head, and driving them out with a punch is a fail. I've bought a plasma cutter, and will experiment with it, but that is a maybe at best. Thus far best success is drilling all the way through with a small bit, then opening the bore with an acetylene torch. In any case it is a time consuming process.
oceanobob
oceano california
general contractor
Thanks for the update on the rivet removal. Does simply heating the rivet with the torch (after the drilled hole) help to drive them out? Will the new fasteners be rivets or some form of specialized frame bolt?
