problema sistema auxiliar botcat t 770
germotor
costarica
mecanico equipo pesado
hola saludos,,,
tengo un problema con un Botcat T770 al usar por un tiempo el sistema auxiliar este se desconecta
me indica q no hay comunicación y deja de funcionar
I'll ask for it to be moved.
I have a problem with a Bobcat T770 when using the auxiliary system for a while, it disconnects, it tells me that there is no communication and it stops working
To comply with forum rules, please post in English in future.
ozarkag
ozarks
Does anything else stop working at the same time? 2 speed or ?
One all too common problem is the auxiliary control unit, or computer box for the auxiliary.
germotor
costarica
Not only that disables the joystick indicates codig H7404 AND CODE M440
germotor
costarica
Or
ozarkag
ozarks
If that second code is M4404, Aux controller no communication, will almost certainly need a new auxiliary controller. And that will most likely need a Bobcat dealer to install and program.
