My lifttruck all the sudden will not go in reverse or forward. I think it is electrical or maybe that inching petal.
I removed the fuse cover on the steering cover and all the fuses appear fine. I checked the electrical connectors for being tight and no corrosion.
there is plenty of oil in the tank and the front diff / transmission. Hyd pump sounds like normal.
I never put my foot on that inching petal because I have read so many bad things on here about it. I only use the brake petal next to the gas petal. I dont know however, there might be a switch in that inching petal that releases the trans from gear. I cannot fine it. I had moved 2 months ago and I cannot find my manuals to my fork lift.
thanks
thanks
