MarshallPowerGen
- Joined
- Nov 26, 2017
- Messages
- 471
- Location
- Northwestern USA
- Occupation
- Generator Technician & Equipment Mechanic
What do you think is in the bottom left of your 4th picture?Doesn’t have a lift pump.
Correction. The gentlemen were discussing it having an electric lift pump which it does not. I should have said it has a mechanical lift pump which you can’t run to prime the system. It has a Delphi primer bulb.What do you think is in the bottom left of your 4th picture?
It would have to get through the cartridge filter but a strong possibility. I took the three injector lines loose at the pump and cranked it. I am getting a 1-2-3 pulse and good stream. Could an injector be stuck open? I went from no fuel to a flood and really hadn’t touched anything except filters, shut off solenoid and I did remove #3 fitting at the pump where the line fits. I was careful and got the spring back on the seat and everything lined up. I was using a magnet and the seat the spring sits on did come out. It had a splined type arrangement and went back in easily.Do u think some of the old line got sucked/pushed into the inj. pump and is now sticking the pump causing the run away and or poor performance.??
Without the shut off solenoid I used that manual shut off to kill the engine.Does the lever you have circled on a pic before (it's the manual shut off) pull the throttle down to off/idle, doesn't matter if it's funny or not should still do it
I'd recommend picking up a low pressure inline electric pump to get it primed. They're not that expensive and will properly push all the air out of your system so you can diagnose what issues you're actually dealing with. There are no shortage of engines that are a nightmare to prime with just a bulb or lever, so I always have one on the truck.Correction. The gentlemen were discussing it having an electric lift pump which it does not. I should have said it has a mechanical lift pump which you can’t run to prime the system. It has a Delphi primer bulb.
I am knee deep into this whole thing. Old wiring and relays are fighting me just to be able to start the engine. I have a plan for that once I get the demons exorcised from the engine. All the fuel lines have the wire type clamps. I am replacing them as I go with stainless worm gear clamps.I would just put the electric pump in place of the priming bulb if it is held in by hose clamps, but I know how Perkins sometimes loves their crimp fittings...
