greerco
Hi, So today one of my good customers came to see me. Story is on 24-07-16 i did a safety on his dump truck. At that time i repaired a crack in the rear cover of the power divider. (it was leaking at the cover weld) On 15-10-16 (almost 3 months later) i got a call that his power divider was red hot. The lower shaft front bearing had cooked. (all other parts looked great except for the obvious metal shavings in residual oil left in the hubs and tubes. I went to drain the differential before removing it and there was little oil in it. Less than a liter. So i removed the diff and put another in....so today he comes to see me and questions weather i put oil in the differential after i welded it back july. The truck had driven 12000 plus kilometers since i welded it with out any issue. I remember clear as day filling the differential with oil after i welded the cover months ago and it had been going without leaks or issues. This is a good customer of mine. Any suggestions. Just a fyi there was no trace of a leak on the truck and the truck runs every day. I swear its like somebody drained it.. Not me.....
I've been doing this for many years. Years ago i had a apprentice forget to fill a diff and it didn't last 100kms...let alone 12000...
If there was no oil in the diff how did the metal filings get into the hub bearings on both sides? .
Im at a loss of for what to think..
Any thoughts?
Any thoughts?
