Yellowdog
- Joined
- Oct 22, 2004
- Messages
- 208
Get the gussetts welded to the boom arms to prevent cracking. the G series came with the gussets from the factory but the C and F series needed them as a dealer add-on. Won't cost much and you could do it yourself if you are a good welder. Look at a G series machine's lift arms (the front) and you'll see what I'm talking about. I had a C series and G series and put about 3500 hours on the two. Good machines. C series is prone to hydro leaks (o rings) and be sure to replace that timing belt now!
The c series leaked all over the place but most of it was easy to fix. Check your chaincase oil while you are at it. You have a great machine for pushing and digging. the power to weight is good with the 863's..
