Is that ice in the pond?
WaterIs that ice in the pond?
Not cleaning, but this one will take a minute.View attachment 290394View attachment 290395View attachment 290396
It's only about a 4' long pipe, so it's down about 3'. Getting that pipe down, and getting rock around it is the only way to pump the water off. Any kind of a hole just fills up with sand. The rock even plugs up with sand, we've had to dig down a foot or so around the pipe by hand a couple times and get clean rock back around it so the water can filter through. That sump pump runs for about 4 minutes out of every 5, on for two, off for one, etc.How deep did you have to sink the HDPE temp dewatering pipe?
Sometimes. This one should have been cleaned back in '21 when we were dry.Does it help when the ground is partly frozen?
do you have the 290 there for reach and use the 210 to sidecast (transfer) the dirt further from the pond into a windrow?210 has still got it. Not as pretty as some, this one was big and wet. Had a 3" pump running for 12 hours and couldn't get the water pumped out. Lots of ice and runny muck to contend with as well. View attachment 299782View attachment 299783Oh well. Come spring it will look amazing lol.
I pulled the original spoil banks back with it, then it sat up high and bailed the muck over the bank as I pulled it out of the water. I'm not sure it would have been able to get down in as far as I did with the 210, and the extra reach even if it could wouldn't have given any kind of tactical advantage anyway. My guys don't get to spend much time in the big hoe, so I let him do the easy job since I needed to be the one doing the dirty work anyway.do you have the 290 there for reach and use the 210 to sidecast (transfer) the dirt further from the pond into a windrow?
Whatever the standard length is, like 9'8" maybe?Is your Case 210 a regular stick or long stick. Great photos by the way.
Simon C
