Goldknight
Fixing up a older backhoe and I have 2 on the grease holes that are plugged. There both on the backhoe swing pivot. Yep there has not been grease in either ho0le for years it seems.
I did get the top pin out and cleaned up. I can see where the pin has moved metal around in the hole and this has plugged the grease pathway. I tried to drill it out but no luck that metal is very hard.
How do you experts out there deal with this kind of issue?
Thanks.
Thanks.
