OldandWorn
This may be difficult to describe and a bit winded so I hope the pics will help. When I was greasing the outer sproket axle support on the left hand side I noticed that the grease was just oozing out of the crack and not seeming to stay inside like it did on the right hand side. I removed the 5 bolts to take the cover off and noticed that the outer housing which is attatched to the track rail was egg shaped, meaning there was no clearance at the bottom but a larger gap on top. I looked at my parts manual and noticed the 2 o-rings that seal the outer and inner parts and understand now why the grease was oozing out at the top. Either because of damaged o-rings or there is now too much clearance on top to seal properly.
What I didn't understand is how 2 parts that normally don't move could get worn out like that. I watched the inner hub while the machine was moving and noticed the part was moving up and down about 1/8" per revolution of the sproket. The inner part is what holds the tapered roller bearing which supports the outermost part of the sproket shaft.
1) Is it possible that my sproket shaft is bent? What else could cause the hub to move up and down with sproket rotation?
2) Does that grease fitting only grease between the hub and rail support or does it supply grease to the outer tapered roller bearing also. Looking at the cutaway drawing in the service and parts manual I don't see a path for the grease to get to the tapered roller bearing.
3) A couple ounces of final drive oil dripped out when I took the cover off of the inner hub. Normal?
4) The washer behind the BIG nut has a lateral crack in it.
Thanks for any help!
