SeaMac
I'm aware that a lot of Pipe Crews use an in-the-pipe or invert laser, for us that's just not practical as our pipe is usually already sitting in water while laying. We use a target-on-a-stick so to speak, it has an inverted "V" as the foot to center on the pipe crown and a telescopic "stick" with a hood on top that has an angled mirror so to reflect downwards the crosshairs. With an in-pipe laser there wouldn't seem to be much issue regarding keeping the target plumb and level, with our approach however it's usually duct taping a torpedo level to the stick. The inherent problem with this setup is we generally only tape the torpedo to one axis that being side-to-side, now I know that keeping the pipe running straight -to minimize deflection- is important but surely the front-to-back axis is as important if not more, you know maintaining slope and all. I have yet to witness sewage flowing up hill therefore it is equally important to have the target plumb on both axes.
Being one who finds a problem in need of a solution and quick -too quick at times- to devise/design said remedy have realized that a bullseye type bubble level inside the target hood also reflecting downwards would appear the simple fix. Using the same principal employed to level the mounting plate on an Instrument only in this application we're looking up to confirm "plumbage" not straight ahead. Sure, there could be trouble viewing the ring and bubble in low light conditions but there are solutions for that as well, one being the self-luminous fiber optics used on hunting bows another being the use of tritium backlighting as used in weapons sights.
So before I go about designing such a target, has anyone seen, heard of or used such an animal?
