Pintle hitch modifications
Acoals
Wisconsin
Yes, that was the one, as near as I can tell. I am right at about 50k with the 315c on the trailer, but the vertical load is the real trouble:
I am over twice that on the tongue.
1693TA
Farmington IL
FAA Radar Engineer, (Retired)
I've installed two of those myself on end dump trucks through a 1" plate braced angular to the internal frame stubs. No idea what is pulled but always thought it had to be heavy to warrant such a hook.
1693TA
Farmington IL
Those are great too but for an end dump that works off center the rotating type offer advantages. Been a couple of trailers through the shop we had to cut old tongues from to replace from being twisted.
FWD
Barron County, Wi
I hauled pulpwood with a pup trailer for many years, like about 35, and since then have used a dump truck to occasionally pull a 3 axle 25 ton equipment trailer. I would never haul unless I had the air pintle. It has a type 24 air chamber for the pressure. I have used Holland pintle's mostly, there are others too.
FWD
heymccall
Western Pennsylvania
FWD
mx727
Memphis
My last two trucks came with 50 ton hitches. Overkill, but never have to worry.
First was air, I liked it. Second is swivel. I like it better for off road use. Can't hear it banging around as there really isn't a lot of slop.
Jumbo
Black Diamond WA
retired
Sign me up as a dummy, I thought any thing with air had to have an air pintle per DOT. Weyerhaeuser Snoqualmie in about '77 went through and changed out all pintles to air.
