Clawed Backster
The original ones may have been, but the ones(one) it currently has is 1 inch in diameter.those pad pins are larger than 1in
Thanks guys.
I picked up some cold rolled 1" stuff today. Now I have to figure out how to drill it for the keepers. My cheapo HF drill bits probably aren't going to be up to the task.
While I agree that 1" seems really small for this application, it is what the machine had when I got it. It appears that nothing on the machine has been greased for YEARS, and it is amazing to me that all of the pins and bushings in the loader and the hoe are in pretty good shape. I will be checking out the stabilizers and pads much more closely tomorrow.Mild steel isn't the best for pins. 1045 is common. Mild steel might bend and will wear fast. Obviously 1" isn't large enough if the old pin broke. What shape are the bushings in?
Thanks for the tips.Oops ! I should have said the stabilizer arm eye.
The wear on those pad eyes are normal for a high hour machine. The end of the stabilizer can be repaired with some heavy wall 1 inch id pipe. I have done it on the inner ends of my own bh. The pipe can be cut long enough to meet the pad eyes.
I drilled the pipe in the center and threaded the hole for a grease zerk.
I can post a link to the pipe source if you want it.
