Pettibone super 6 parts needed
Paris Idaho
IT moving into farming
Hello all,
I'm new here but I love old machines.
I have partially resurrected a 73 Pettibone Super 6 but I have one issue.
Sometime in it's life the ring gear and pinion carrier housing broke loose from the axle housing and damaged the ring gear and pinion. It isn't going to last long. Does anyone have one of these machines around for parts? If I can get this fixed I'll be using this thing for years.
Thanks
I don't know of any parts machines. You might be surprised how long it lasts the way it is, then again , i havn't seen it, you have.
If you need the parts, figure out the axle make and model, because you'll have better luck if it's not Pettibone.
Paris Idaho
Thanks. That model numbers you found sound correct.
My machine has the Napco axles but, I didn't have the model number handy.
Paris Idaho
On how long it might last. Your right . It is amazing how tough these things are. That said. The pinion gear has lost at least half an inch of it's diameter. The gears look like they have been dragged around by a chain over rock for a week. I can run it on just the front axle but I would like to get it all back up to a reasonable repair level
Vetech63
Oklahoma
Give me the model and serial number of your machine and Ill check the log records on it, providing they are still available. I'm a Pettibone Distributor here in Oklahoma.
Paris Idaho
I have the build log . See attached
Thanks for checking if the parts are around!
  • Super 6-1751.pdf
