Second stage relief, pilot lockout, merge-divide, travel junction to name a few more,
Have you confirmed pilot pressure? 3-4 Mpa. Pump standby pressure? 3.6 mpa. What does gauge show for hyd temp? Hot by touch is very subjective, machine can be at 60 degrees C (140 f) which would feel hot, but is normal operating temps.
Theese machine have an unloader valve and a main releif. In neutral when destroked all oil should be flowing out unloaded valve at standby pressure.
