PC120-6 swing break will not release
Dunderhead
Washington
Hey guys, I have 120-6 that the swing break will not release on. I can operate with the override switch on.
With the override switch off and the brake turned on…I can sometimes get it to unlock for a brief second by turning while switching the brake switch off.
I replaced the top solenoid in the tree next to the pump and no change. I was told that is the swing solenoid.
I am at a loss as to what to do next. Any suggestions? Thanks in advance!!
funwithfuel
Will county Illinois
Mechanic
The Komatsu unlike other brands gives you the option of locking the swing. Most others don't give you that option. That is how it's designed. It's not an override to release, it's override to lock. Release should occur naturally every time you move the stick.
Dunderhead
Washington
Code:
there is an override toggle switch hidden inside the fuse box. When you flip the switch I think it bypasses the solenoid and allows the machine to spin.
funwithfuel
Mechanic
I was under the impression you were referring to the swing brake switch. I'm guessing you're losing signal from the swing pressure sensor. Can you access the service mode. JohnC has put together some terrific tutorials on YouTube to help you. Once inside service, you can monitor swing PPC or pilot pressure control. Odds are, it won't change.
Dunderhead
Washington
I do not think i can access the service mode....
LACHAU
Saigon, Vietnam
You are both right!
The Komatsu PC100-6 has 2 switches that affect the "SWING BRAKE" system.
One switch is called "swing lock switch", and the other is called "swing lock override switch".
Dunderhead
Washington
I’m hoping to tackle it Friday.
if I am reading this correctly the swing brake solenoid valve is the 4th down on the tree? The local machine shop told me it was on the top?
LACHAU
Saigon, Vietnam
You are right.
"The swing brake solenoid valve" is 04th on the solenoid valve block.
By the way, I suggest you carefully check the swing brake solenoid valve's wiring and connector.
