You have all the make it easy tools. Your probably like me started off with a rock and a stick and worked your way to some stuff that you needed when you started out.Oil hubs run cooler, check them with infrared gun. Cattle haulers get dinged because it's a cattle hauler,
notorious.
Oil bath seals go bad prematurely because-
#8 Did not use proper equipment such as wheel dolly, or adapter on jack for air disc hubs and damaged
seal installing hub over spindle.
