Yeah, it would be a nightmare if there was an electrical problem.
Oh! come on! You know all the wiring is routed safe and tied down to prevent rubbing on sharp edges!Usually ends up Dash on FIRE!!!!
Years ago working construction driver calls in he was close to shop & had a electrical stormOh! come on! You know all the wiring is routed safe and tied down to prevent rubbing on sharp edges!
Kinda makes ya think where the world is going?……(JMO) or course.Some might consider this a little over the top {an over load of sorts}. If he had left the
skull off the top it would have been just right, that addition was just a little too much.
Don't even think of a Sterling.Every freightliner I've been in, or looked at, that had that dash- the dash was all broken up. ...
Talk about distracted driving.Some might consider this a little over the top {an over load of sorts}. If he had left the
I haven't driven it. Friends have a 1998 Sterling tandem dump. It has a great many miles on it. Son,(50) parked it on a gentle grade in gear, didn't set the spring brakes & took another job. Truck sat unused a month or more. Father, (75 at the time) felt it should get a bit of exercise. He climbed up, put it out of gear, started it. After it built air enough to release the spring brakes, it rolled down thhe hill smashing through the wall of the building.Driven a Sterling, would have been better off continuing the L LT LTL LN series than build those.
Some of the schit I would see in 3rd world countries, namely the Arab ones.Some might consider this a little over the top {an over load of sorts}. If he had left the
