mikebramel
The case pressure is probably getting too high, is the pump vented to the inlet or externally?
it does have pressure on tank.also, a 225 should have pressure on the oil tank. maybe a clogged filter?
Yes.did you do you do a thorough cleanout?
Maybe, Steve. Maybe not. A pump usually starves for oil on the suction side of a pump when a hose collapses. It would be almost impossible for a hose to collapse on the output side of any pump. Have you checked the pump pressure yet ? Might be waaay too high. Does it make any noise before the gasket blows out ? Might be a warped pump housing from improper torque values on the body of it.[/QUOTE[QUOTE="Steve Young, post: 723780, member: 65581" The dealer thinks it's being caused by a collapsing hose.
Maybe a mouse got in there...
