I seem to always battle the same ongoing problems. I thought maybe some input from others may help. Let me try and explain. I tend to get long winded, so my apologies in advance.
I build grain storage tanks and grain handling equipment, both commercial and on the larger farms. Some of the smallest storage tanks I build are 30,000 bushels or so. The largest I've built holds 600,000. I'm bidding on some that hold over a million bushels. Grain weighs 56-60 pounds per bushel. Figure it up..There's a lot of weight on the ground..60 million pounds. Needless to say, the foundation has to be right.
Manufacturers of grain storage tanks offer different foundation designs based on different soil conditions. But, all of their designs state the normal ..They're not responsible, these are just guidelines. Depending on the size of the tanks, their designs are based on soil bearing capacities of 3,000# per square foot, up to 5,000# per square foot. The small 30,000 bushel tanks haven't been a concern, but, the larger tanks are. Typically the basic foundation design is an Inverted T. A footing around the perimeter, 5-12' wide reinforced with rebar, then a wall on top of the footing 15" wide and 2-8' tall.
This part of the country where I live and work doesn't have rock. Clay dirt is typical. We're loacted between the Mississippi, Ohio, and Tennessee Rivers. There's a lot of low lying bottom type ground that has filled in for millions of years. I know from experience 3,500# soil bearing capacities is hard to achieve. There's several locations I've uilt on that were at 1,000# or less.
The right way to do a project is to start with soil borngs. Soil boring reports come back and to me it's mostly jibberish. I'm a contractor, not an engineer. I like the borings to be overseen by a reputable engineering firm,who reads and interprets the reports, then tells me how to build the foundation based on the actual soil consitions of the site.
Some of these larger tanks cost well over a million dollars. Engineering and soil borings cost $5,000-10,000 depending on the scope of work. I'm a simpleton, but, it's a no brainer. DO the soil borings. But, time after time after time, the people want to proceed without the soil borings. WHY would they balk at this? I just don't get it.
(cont)
(cont)
