Davo
G'Day folks, I have just got an old sdk6 to use around a small farm, I hav'nt messed around with these things before but like to have a go at my own repairs so any advice you may have would be much appreciated. The engine is good. The hydraulics for lifting are no worries, but, the drive hydraulics are straining under a small amount of load (slight hill) or when turning it will only turn in a large circle not on the spot (there's a fair bit of noise - almost a grinding feeling associated when trying to do a tight turn). I have ordered a new hydraulic filter and plan to change the oil out at the same time (previous owner told me this would fix the problem) the oil does look pale (like my beer! but thicker). Is there any way of knowing the age of this machine? the frame number is 13541, dumping height , 2200mm, capacity 450kg, weight 2140kg. Cheers Davo.
