Wow thanks for the heads up on that. What is Black Beauty? Never heard of it?
The plan is to restore this back to like new condition and rent / lease it out. So far I have all new hose, wire, control panel, joysticks have been rebuilt too. I thought I'd leave all the old fluids, hoses and wiring on before the blasting. After I'd change the hoses I'd flush the system out with the cheapest hydraulic fluid I could find, then refill it with something good. Only one cylinder is still on there (the main lift cylinder). Here's the problem, where the main boom is there are drain hole areas. Over its working life it was used to repoint chimneys, etc. and enough cement has fallen in there where now that whole middle area won't drain. It needs to be broken up somehow. I tried with a hammer, to risky, there are fittings, hoses, etc. buried in that cement.
