I'm with Ronsii, Need to climb up under that machine and loosen the access plate and let the water out, fix the swivel boot, check the fill access hole on top for a bad gasket/ loose bolts. You will more than likely need to change that grease out, Kind of messy job. Most have a grease cavity that holds up to 5+ gallons of grease. The swing gear from your swing box lies in about 1/4 inch of that grease and is pulled up between the swing gear and turntable gear to lube it. I would also grease the bearing a little more often until you get it straightened out. It takes some work to clean that cavity out.
