Oil for cat 955l
Xaris
GREECE
Operator
Hello.
Can i put the 20w 50 in the motor ?
Sorry but i dont speak the language goood.
Dickjr.
Kentucky
I think when these machines were built the oil of choice was 30W. I never really heard of anyone running 20W50 unless its a real hot climate. Typically 15W40 is what most people run which covers a wide range of temperatures. And it gets very thick in colder weather.
Greece gets pretty hot in summer but quite cold in winter, it depends whereabouts in the country you are. If it was me I'd be running a 15W40 or even 10W30 API CH-4 spec oil as a minimum requirement. IMHO 20W50 is a tad too heavy for cold starts in winter when the ambient temperature is around or below freezing point.
Xaris
GREECE
Operator
I'm afraid for the oil piston ring.
Maybe a 15w 40 pass easy inside the combustion chamber and i'll have increase οf consumption oil.
Here in Athens rare has temperature below freezing point.
Thanks.
All 15W40 means is a 15 weight oil that behaves as a 40 weight oil at higher temperatures. W is just for weight.
Actually the W stands for winter (viscosity when cold) not weight. It was even a question on one of the TV quiz shows.
