oil capacity case 1845c
Terryz
jeffersonville, ny
Anyone know the chaincase oil capacity of a case 1845c? the machine came into our shop with the cases drained. I don't see any level plugs. Thanks, Terry
kshansen
Central New York, USA
Check this link:
http://www.colemanequip.com/SpecSheets/1845C.pdf
Capacities are bottom center of the first page.
I believe Case recommends engine oil in the chain cases. Some may disagree, but as all that is really in there are three chains and half a dozen sprockets, I think any oil would be fine. Compared to the chain on a motorcycle they live a good life if you can keep the water out! Shock loads from show-off operators will do more damage than anything else.
If the compartments are dirty or have signs of water I usually would dump in a couple gallons of fuel oil and block the machine up so you could spin wheels back and fourth for several minutes then drain and fill with clean oil. New seals/gaskets on the four covers is a good idea, check them for cracks around stud holes from someone over tightening the nuts.
