watglen
- Joined
- Apr 3, 2009
- Messages
- 1,324
- Location
- Dunnville, Ontario, Canada
- Occupation
- Farmer, drainage and excavating contractor, Farm d
D6T zjb00289 2011 or 2012 model
Weirdest thing. Dozer has a habit of failing to crank. You get a a bit of clicking etc like a dead bat. Problem is most common when the machine has sat for a couple days, and doesn't present itself if the machine was run yesterday, just like a weak bat. Machine will fire if you hook a jumper cable to it, just like a weak bat.
The weird part is this. The operator discovered if you turn the key to on and let the computer get to its happy place, like normal, then further turn the key to crank and hold it there, nothing will happen for about 10 seconds, and then the machine will crank fast and fire right up. Since he discovered this, he uses it every time. No boost required.
Wtf is going on here?
TIA
TIA
