No power TR270
abilenetr270
Abilenem TX
I had a 3071 fault, fiddled with injector connections, then got a 3218 fault. Went and fiddled with connections again and when I got back into cab, absolutely no power, no lights, nothing. I checked the fuses in the cab and the unswitched battery fuse looks ok, swapped it with the telematics one and still now power! Any ideas what to try next? I just need to get it going so I can limp mode it onto a trailer so dealer can look at the initial problems! Thanks!
abilenetr270
Abilenem TX
OK, got power back in my TR270B. Still getting 3071 fault intermittently. Does anyone know how to open up the circuit box in the engine compartment pictured here? The mechanic told me on the phone there might be a frayed or corroded wire in there. It looks like there are little tabs but felt like I would break it before it would release!
Canuck Digger
Mission, BC, Canada
Business Owner, Equipment Operator, Fishing Guide
Sounds like you might be able to get it going to put on trailer. When my TR was in a no go mode with a bunch of error codes, I ended up hiring a crane truck to take it to dealer. Wasn't bad $ wise. Good Luck. I have the same machine, Too many wires and sensors in them now.
