Hi All,
Case 580f (French model).
Have been digging clay today, not easy stuff to move, and when lifting out of the hole the boom is struggling to lift a full bucket. Power enough in bucket curl and dipper arm to fill bucket but then struggle to lift it. It is an old machine, no hydraulic leaks, hydraulic fluid recently changed when I had swing cylinder repaired. Just wondering if it could be the seals inside the boom cylinders that are gone, no external leaks and I know the pump will probably be well worn as well. Any advice appreciated.
