tightgtp
- Joined
- Nov 8, 2009
- Messages
- 94
- Location
- illinois
- Occupation
- lead service technician for the largest forklift c
I have a Case 621 that lost pilot pressure for the lift. The steering works fine. I only have 25-0 psi of pilot pressure at idle. After troubleshooting I found the two check valves that connect the hoses from the steer pump and hyd. pump to the pressure reducing valve trashed, the ball and seat was wore out and the spring broken. I have new on order. Has any one else had this problem? Your help is very appreciated.
