Hi all, I have a JCB 214 series 3 on an island in the Bahamas. The s/n is 0900368. The problem is we have lost all drive to the wheels. It is 4 speed with a shuttle change on the steering column. It is leaking some fluid from around the gearbox/torque converter case but I can't see where it is coming from!
When you put it in gear and place the shuttle into forward or reverse it doesn't jolt as if it has engaged. But if you Rev the engine fully it tries to move forward or backward. I am hoping this is an easy fix, something I might be overlooking? Any help would be gratefully received.
Cheers
Malcs
Cheers
Malcs
