Hi every one I'm a new skid steer owner and i got a 2006 tl140. I got a grappling bucket for it and I found out the aux controls don't work. also if it maters the float control and the travel speed switch don't work. i have checked the safety switch doesn't seem to mater if the bar is up or down doesn't stop the machine from operating. also tried bypassing the switch itself to make sure it wasn't the issues. being bypass didn't change anything. I have been reading on here and keep seeing something about a safety switch bypass to connection and was wondering were that may be at. someone said maybe over the battery but i don't see it anything there. There is a set of wires that might be it but they have wire nuts on them instead of the standard bullet connections, they are at the top of the engine bay towards the cab and one is connected to the ground bolt. i also tried tapping by the relay switches as suggest in other forms and got nothing. any help would be great really don't want to replace a 400 dollar control on both sides for it to be something else.
thanks for any help in advance
