Ok...salt water has rusted this machine badly. The pressure relief valve in question, part# 6674259, is rusted through and leaks profusely. Even while not under pressure and machine off. Ths spool block is a 7 section (5 spool) assembled block. It all dismantles and held together with 2 tie rods. I am posting pics from machine and from bobcat website. Relief valve #12 on diagram is the bad one. It can be located on bobcat online parts under ------300 series 514013001 & above-----, control valve(5 spool). I will try to locate a part stamping but due to it being individual parts i dont think i will be able to. I hope this expains it well. Also....i can find the part right from bobcat but i am absolutely blown away at the high cost for such a common and simple pressure relief valve when most others are 6 times less cost. I fear i may need more valves (rusty spot) . And at these prices it will cost me $10,000 to rebuild a spool block for a 3 ton machine. Just frustrated!!!!!!
