Syclone538
Just got an older (early '80's?) 410 that needs a little attention, looking to get pointed in the right direction. I know a decent amount about working on cars, but completely new to heavy equipment and diesels.
Hoe arm
(l<-) B
T33931
RR Frame
9410 0417251
RF Frame
410-D 292515T
Engine
4219DT 03 449301T
What year is it?
Where is a good place to get an owners manual or service manual?
Temp gauge doesn't work, not sure how hard that will be to fix.
Oil in the coolant, but I don't think any coolant in the oil. Radiator cap lets coolant run out the overflow hose (no overflow jug, planning on adding an aftermarket jug once I figure out the oil in the coolant) and I'm somewhat afraid when I get a new cap on it and it builds some pressure it will push coolant into the oil. Looks like oil lines go to water pump, I assume that is used as an oil cooler. Hopefully this is where the oil is coming from? Does this engine have a dry deck head? Would a head gasket let oil into the coolant?
Wanting to change the oil very soon, to make sure there is no coolant in it, what oil should we use?
Has some kind of charging or battery problem, or a short somewhere draining the batteries. 2 6 volt batteries, the previous owner said they're about 2-3 years old. Have only had it running for about a half hour, and in that time I'm pretty sure the batteries actually discharged. Red light with lightning bolt was on sometimes while running, pretty sure it was not constantly on while running.
How much water should be in the batteries? 5 of the 6 ports, the water was just above the plates, about an inch down from the top. On the other, a plate was slightly above the water, so I added just enough distilled water to cover the plate, just like the other 5.
When you let the clutch out, there is like a 1 or 2 second delay before it starts moving. Is this normal? Or are you supposed to put it in gear and let the clutch out, then use the lever on the dash? Does it matter?
We need teeth for the hoe bucket, just get them at the dealer, or is there a better deal somewhere else?
That's everything I can think of right now, I'd appreciate any help you guys could give me.
Hoe arm
(l<-) B
T33931
RR Frame
9410 0417251
RF Frame
410-D 292515T
Engine
4219DT 03 449301T
What year is it?
