brubro
Hello all,
I've got a problem and thus a question about a New Holland L785. The main boom just started lifting slowly, and it is no longer lifting smooth. You can feel a jerkiness to it that was not there before. I am concerned that the actuators or the pump is in need of repair. There seems to be a new noise coming from the pump area. When I lifted the seat, I could see one of the actuators vibrating as the machine idled. The noise seemed to be in the general vicinity of that actuator.
The boom drops normally, as expected. The hydraulic fluid level is fine. The tilt works fine, so I am assuming that the pump is probably OK. I did a search on this forum and didn't really come up with anything similar. Can you rebuild the actuator (s) if they are the culprit?
Any advice, knowledge or experience would be greatly appreciated.
