vale4494
Hi all, I am in desperate need of help. I have a 2016 New Holland L220 and it stopped running while I was working around the yard. It was low on fuel but I don't think that would cause the issue i am having. My issue is that i have no lights on the cluster and the machine will not crank when i turn the key. I power to certain fuses in the fuse box. and i have power to certain pins in on the cluster. i have power to the ignition switch. The diodes that I have found are different than the ones i have seen posted on here, not sure if i just have a newer machine or maybe I did not find the correct diodes. If anyone could point me in a direction to start looking from here i would really appreciate it.
